random in Foreach
   8381   6   3
How to delete faces in Foreach randomly for each group?
You could just sort the faces randomly and delete a range. If you need to delete a specific amount of faces for each group, you could run a for each loop on each group and do the range delete there.
DASD
Thanks for reply
I am trying to do something like this
I have 3 grids. Each grid is in it's own group so I have 3 groups of primitives
I want to delete primitives randomly in foreach and when I do that with rand($PR) they, of course, deleted similarly so I get this
so how do I delete them randomly for each group?
Need to change your seed value based on the copy number. You will need to stamp for that.
DASD
I don't know how to stamp in foreach. Can you please write expression?
https://vimeo.com/142534639 [vimeo.com] - watch this.
In the old foreach SOP the expression was soemthign like: stamp(“..”,“FORVALUE”,0).
In the new foreach you will need a wired metadata node and you get the iteration number with detail(“../metanode”,“iteration”,0)
DASD
That helped
Thanks a lot
