So in those tools you can quickly create for example a cloud, you basically click on it and it applies properties to a polygon object.
Well, what are these off the shelf tools? Are they considered tools like the extrude tool and basically an essential piece of the software? Because they seem to me like, something like a special photo filter which is applied to an image. It's slapped on there and you get a certain kind of effect like let's say increases contrast and black and white and you're done. Or you could those kind of adjustments manually so you have done them sort of properly and individual to each image. Is that more accurate?
The reason for asking is when I tried to go deeper in some of those nodes there are a couple of other node trees I couldn't access which led me to believe that the shelf tools are kind way to simple put a “filter” (so to speak) on there which gives you immediate results, but if you want it to be perfectly fitted you need to build those trees all yourself?
Or is it just a tool like any other and off the shelf simply means those are prepared tools and if you want to individualise those effects then you need to program a new tool?
So proper tool or just a preset?
Seems like kind of a dumb question but it just kept bugging me
