Using Attribute Create you can create an attribute with type “Integer Array” – is there a way to do this with c++ and the HDK?
The best I can do is to create an Integer attribute with size N but this results in N integer attributes (attr..attr) instead of one attribute with array data.
Just wondering if anyone has done this… thanks!
Creating an integer array attribute with HDK?
2296 2 1- jrichards
- 5 posts
- goldleaf
- スタッフ
- 4201 posts
I tried dabbling with array attributes a bit over the summer (I'm a REALLY BAD programmer), but there is an array attrib example in the HDK:
$HFS/toolkit/samples/SOP/SOP_ArrayAttrib.C
I was also given this little snippet for Vec3 arrays:
I can't find my little experiments. But hopefully those help a bit, and maybe someone more knowledgeable will chime in.
UT_FloatArray fdata; UT_Vector3Array vdata; GA_Offset ptoff; GA_FOR_ALL_PTOFF(gdp, ptoff) { // Fetch array value aif->get(attrib, ptoff, fdata); // Convert UT_FloatArray to UT_Vector3Array // NOTE: /3 for non-negative integers rounds down // if fdata.size() isn't a multiple of 3, so it's safe for that possibility. int vsize = fdata.size()/3; vdata.setSize(vsize); for (exint vi = 0, fi = 0; vi < vsize; ++vi, fi+=3) { vdata[vi] = UT_Vector3(fdata[fi+0],fdata[fi+1],fdata[fi+2]); } // Do something with the vectors for (exint vi = 0; vi < vsize; ++vi) { // This is just an example of something to do vdata[vi] *= 0.5f; } // Convert UT_Vector3Array to UT_FloatArray for (exint vi = 0, fi = 0; vi < vsize; ++vi, fi+=3) { fdata[fi+0] = vdata[vi][0]; // x fdata[fi+1] = vdata[vi][1]; // y fdata[fi+2] = vdata[vi][2]; // z } // Write back aif->set(attrib, ptoff, fdata); }
Edited by goldleaf - 2018年4月24日 23:59:17
I'm o.d.d.
- jrichards
- 5 posts
