Hi
I am learning Houdini and come from a VRay background with 3ds max.
Usually I would render out Diffuse Filter, GI, Reflection, Refraction, Specular, Lighting, AO, Z Depth and Mattes for compositing. I have done alot of research into how this is achieved in Houdini 15 but have not figured it out.
Does anyone know of a good tutorial for 15 that would point me in the right direction ?
N
Render Passes/Elements
4153 3 0- Niall Cochrane
- 21 posts
- Niall Cochrane
- 21 posts
- marcotronic
- 8 posts
I've just started with Houdini a couple of days ago myself, but I found this one here:
http://lesterbanks.com/2014/06/set-export-aovs-houdini-mantra/ [lesterbanks.com]
It's for Houdini 13. I guess it might not be too different in H15 - haven't tried it myself yet, though…
Marco
Marco
- circusmonkey
- 2624 posts
Throw away comparing anything to vray > you cannot even assemble a beauty from vray layers thats correct.
utility image
http://circusmonkey.com.au/circusmonkey/Rops.html [circusmonkey.com.au]
shader mattes
http://circusmonkey.com.au/circusmonkey/Shops.html [circusmonkey.com.au]
Ive not rendered a separate AO pass since 2008. As with PBR rendering and the env light you get AO for free. So its pretty pointless rendering it out on its own.
Rob
utility image
shader mattes
Rob
Gone fishing
