Hi all!
I have trouble to work with houdini engine and vertex color.
I need to both read and write vertex color from geometries with an otl.
Writting vertex color from houdini to unity works perfectly by reading cd point attribute.
But I did not not managed to make houdini read vertex color from unity's game object. I tried to read it from point attribute and vertex attribute, with the same result.
Is there something special to do to read make houdini read vertex color from a game object? Is it even possible to do that?
Vertex color
7124 2 1- slare
- 2 posts
- damian
- 402 posts
We don't currently send back the vertex colors from Unity to Houdini on meshes. We do if you use our painting tools but that's a separate code path. If you just set vertex color yourself on a mesh it won't be sent to Houdini.
If you'd like support for this, please submit an RFE to support@sidefx.com.
- dpernuit
- スタッフ
- 553 posts
