Merge primitive parameters - How?
   1838   0   1
Hi people,
I've done a pyro sim, which I cached to openVDB. Then I've duplicated this cache using a copy node and some geometry. Now I've run into a problem for which I have no answer. In the VDB cache I've deleted the fields which I have no use for ( like heat, velocity, fuel… ), but, when I look at the copy node in the spreadsheet I see that Houdini does not combine the remaining fields. So I have a density and temperature field for every copy.
Is there a way to combine these fields into a single parameter?
EDIT: The way forward is to enable the “Pack Geometry Before Copying” in the “Stamp” tab and all will be well.
Edited by IIBit - 2017年2月17日 03:50:56
Have you tried turning it off and on again?
