Exception in thread Thread-1 when launch houdini
   5007   4   0
Exception in thread Thread-1:
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.16\python27\lib\threading.py", line 808, in __bootstrap_inner
    self.run()
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.16/houdini/python2.7libs\hou.py", line 44314, in __threadRun
    self.__run()
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.16\python27\lib\threading.py", line 761, in run
    self.__target(*self.__args, **self.__kwargs)
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.16/houdini/python2.7libs\hdefereval.py", line 141, in <lambda>
    thread = threading.Thread(target=lambda: function(*args, **kwargs))
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.16/houdini/python2.7libs\hdefereval.py", line 161, in thread_code
    it.next()
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.16/houdini/python2.7libs\sas\localassets.py", line 350, in check_for_shelf_tool_assets
    shelf_tool_assets = StoreAPI(session_data).get_shelf_tool_assets()
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.16/houdini/python2.7libs\hutil\api.py", line 164, in __call__
    hutil.json.utf8Loads(content))
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.16/houdini/python2.7libs\hutil\json.py", line 83, in utf8Loads
    return _utf8Encode(loads(string))
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.16\python27\lib\json\__init__.py", line 338, in loads
    return _default_decoder.decode(s)
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.16\python27\lib\json\decoder.py", line 365, in decode
    obj, end = self.raw_decode(s, idx=_w(s, 0).end())
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.16\python27\lib\json\decoder.py", line 383, in raw_decode
    raise ValueError("No JSON object could be decoded")
ValueError: No JSON object could be decoded
My houdini version 15.0.244.16
how can I fix this problem?
today I try to install houdini 16.0.504.20, same error display, is it my system problem?
Exception in thread Thread-2:
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.20\python27\lib\threading.py", line 808, in __bootstrap_inner
    self.run()
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.20/houdini/python2.7libs\hou.py", line 55260, in __threadRun
    self.__run()
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.20\python27\lib\threading.py", line 761, in run
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.20/houdini/python2.7libs\hdefereval.py", line 141, in <lambda>
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.20/houdini/python2.7libs\hdefereval.py", line 161, in thread_code
    it.next()
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.20/houdini/python2.7libs\sas\localassets.py", line 367, in check_for_shelf_tool_assets
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.20/houdini/python2.7libs\hutil\api.py", line 164, in __call__
  File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.20/houdini/python2.7libs\hutil\json.py", line 83, in utf8Loads
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.20\python27\lib\json\__init__.py", line 338, in loads
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.20\python27\lib\json\decoder.py", line 365, in decode
  File "C:\PROGRA~1\SIDEEF~1\HOUDIN~1.20\python27\lib\json\decoder.py", line 383, in raw_decode
スタッフ
Hi Andy! You should log a bug following the directions in this post.
https://www.sidefx.com/forum/topic/25347/ [sidefx.com]
Be sure to include your machine specs.
Chris McSpurren
chrism
I will check, thank you, Chrism.
We also have the same problem on all windows machines.
