Hi
Is it possible to create a Cop network and have it link to the Projection Map of a light ?
If possible to save time, I would like to be able to work within Houdini instead of going to Photoshop to make changes to the projection map.
N
COP to Light Projection Map
2682 2 0- Niall Cochrane
- 21 posts
- Enivob
- 2631 posts
Yes, there is a special prefix you need to type before the path to the image output node. It is “op:”.
Try something like this…opimg/image1/my_image_output
NOTE: You can drag-drop a node from Tree View into the projection map filename slot.
Edited by Enivob - 2017年3月23日 08:35:02
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- Niall Cochrane
- 21 posts
