Cloth and hair interaction
   1471   0   1
I'm trying to get cloth and hair to interact. More specifically, I have a surface with hair setup on it, and then I'm dropping a cloth over grid over it. I would like the hair to flatten underneath the cloth.
This works when the cloth comes straight down onto the hair. However, when the cloth begins to slip, the hair does not get pushed down by the sides of the cloth.
I have tried adding thickness to the cloth in the cloth SOP, as well as messing with a lot of the solver time settings in case a more detailed simulation was needed.
Here is an image showing some results. As you can see, on the top of the sphere the hair behaves well, but as soon as the cloth slips over the side, the hair no longer reacts correctly and sticks through the cloth
I've also attached my hip file. Does anyone have any suggestions?
Edited by ajk48n - 2017年4月4日 18:13:00
Cloth and wire not working.hipnc (767.4 KB)
