Sometimes when I type a value into a field, like 2, it turns into 2.000000000001. I understand there is a limit to the number of digits in floating point number but I am just typing an number without any calculations. I am curious about reason behind this.
The only time I found this a problem was when I was trying to find out points with certain u value “0.7382”, which was shown on the geometry spreadsheet. I was just using an “if” statement to check if the value was exactly equals to “0.7382” but it returns nothing. I later suspected that there were some digits hidden behind it so I multiplied it by 10000 then converted it to integer for comparison and it worked. Does anyone got a better way to compare values?
Why are values inaccurate in Houdini?
4727 8 1- benC
- 49 posts
- protozoan
- 1718 posts
- SteN
- 55 posts
benCNever, never do that, never try to compare two float to see if they are equal: it will never work.
I had the same problem (see here [sidefx.com]) and what you have to do instead is compare a value (the value you are looking for) to a range, with your example you can write the following code:
if(value > 0.73 && value < 0.74) { //Do stuff }
Or also:
float _tolerance = 0.01; if( (value - 0.7834) <= _tolerance) { //Do stuff }
So basically to get that to work you dont check if the two values are equal, but if the two values are more or less close
Edited by SteN - 2017年4月18日 09:53:15
- BabaJ
- 2129 posts
Also,…it's not a Houdini ‘thing’. It's with how hardware treats ‘floats’.
This link is but once example of the topic and you may want to do some of your own searches to get a better understaning:
https://docs.oracle.com/cd/E19957-01/806-3568/ncg_goldberg.html [docs.oracle.com]
When you have a better understanding, then you will be able to write the code in a way that serves your purpose like the suggestion SteN gave.
- benC
- 49 posts
- benC
- 49 posts
It was working when I use blast @uv==0.7382 to isolate the points but not "if(@uv==0.7382)" in attribute wrangle. Anyone know the reason behind this?
- edward
- 7899 posts
- jsmack
- 8043 posts
- mtucker
- スタッフ
- 4525 posts
