I am playing around with the various options within the transform tool, and find myself wanting to reference values within the node from elsewhere (i.e a null node with custom float parameter).
Right now, the y.axis transform is: fit01(rand(stamp(“../box1/copy1”, “copy”, 0)+435), -3.5, 3.5)
Pretty self-explanatory expression, transforming a box ‘x’ amount of times (determined by copy stamp) along the x-axis between -3.5 and 3.5.
My question is: how can I use a value from a float parameter in a null node and insert it in the place of ‘-3.5’ and ‘3.5’? Technically I can just change the values within the transform node itself, but for visual clarity I want to be able to input these values within a cleaner interface/ a slider.
I figured it would be something around the lines of:
fit01(rand(stamp(“../box1/copy1”, “copy”, 0)+435), -ch(“../Null1/Parameter1/”), (“../Null1/Parameter2/”)
But this does not seem to work.
Cheers
Applying custom parameters to expressions in copy stamp
2846 3 0- Cereal
- 3 posts
- Sean Rowe
- 39 posts
Looks pretty close. I would recommend removing the minus sign on you first channel reference, you can always put that in when you put your minimum value into Parameter1. The second channel reference needs the ch in front of it. You also need to make sure that you have enough closed brackets at the end for each expression you use, it looks like you need one more to close your fit expression.
Edited by Sean Rowe - 2017年5月2日 19:42:38
- sepu
- 457 posts
- Cereal
- 3 posts
sepu
did you try to close you expression you are missing a “)”fit01(rand(stamp(“../box1/copy1”, “copy”, 0)+435), ch(“../Null1/Parameter1/”), (“../Null1/Parameter2/”))
post your .hip
Even after closing expression and making adjustments mentioned above, it still doesn't seem to want to work?
fit01(rand(stamp(“../box1/copy1”, “copy”, 0)+435), ch(“../null1/paramater_1/”), ch(“../null1/parameter_2/”))
Attached .hip file
