Clone Digital Asset with parameter.
   Views 2376   Replies 3   Subscribers 0
I'm newbie and now get stuck in an issue with for-loop node.
I made a beam (digital asset) which has a length parameter.
How can I duplicate the beam into several instances with different length ?
Thank you in advanced.
Maybe my question is not quite clear.
So i attached the file for you guys can review and help me find the solution.
Edited by Trung Tran - 2017年5月11日 00:02:27
PROC_Bridge.hipnc (81.1 KB)
beam.hdanc (4.4 KB)
You almost had it. Instead of “@beamheight” for the parameter value on your hda, use a point expression to get an attribute value from the input. Attributes can only be bound like that in a few built-in nodes. Everywhere else use a point/prim/detail expression.
PROC_Bridge_edit.hipnc (81.1 KB)
jsmack
Thank you. I made it with some approaches. One is using ForEach Loop and one is use stamp function and copy SOP.
And thank you for your help.
