Hello
I've encountered a very strange Mantra issue.
I have a long render sequence and Mantra renders it just fine, but the problem is It suddenly stops for absolutely
no obvious reason.
interrupt it and hit “Render to disk”, It starts rendering till It stops again, around 6 to 300 frames ahead randomly.
and this story goes on and on.
I cached out the entire geometry and red it back with no luck. the same rendering interruption.
please let me know if something is wrong.
thank you
Mantra, image sequence rendering problem
5194 6 1- MirHadi
- 147 posts
- Enivob
- 2630 posts
You could investigate the basic culprits, being heat and free disk space.
Monitor your system heat when rendering and make sure you have enough disk space available.
It kind of sounds like your problem might be hardware related. If you have a mechanical disk drive try running/scheduling a surface test. Perhaps one of your cached files is stored on a bad sector..?
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- MirHadi
- 147 posts
- toyo xvx
- 1 posts
hadi jam
Hello
no obvious reason.
thank you
I have this problem as well.
How do you fix this?
- Physalis
- 13 posts
I don't know if it's related to this problem, but I have a similar problem with Mantra freeze ( http://forums.odforce.net/topic/30283-mantra-freezing/ [forums.odforce.net] )
- snda93927
- 1 posts
- neil_math_comp
- 1743 posts
Try the latest production build [www.sidefx.com], H16.0.663, or the latest daily build [www.sidefx.com], H16.0.666. There was a displacement-related deadlock fixed a couple months ago in H16.0.600.
