It seems like when ever I import an obj, or use one of Houdini's UV tools, it breaks up each polygon into a UV island. When opening the obj in zbrush or 3ds max, it is indeed the case that each polygon became it's own uv shel. Even after adding a UV Fuse node, each polygon is it's own uv shell.
Houdini breaking up polygons into UV islands
10108 5 1- uuLLFA
- 90 posts
- jsmack
- 8052 posts
- Benjamin Lemoine
- 143 posts
You can promote uv to point but your mesh has to be split on the seam to keep the uv island separate.
there's no good solution appart to fuse them in max…
It would be nice if Houdini could fuse the vertex on uv island at obj export !
especially for games (cause the more seams you have the heaviest it is for the engine if i'm right)
Edited by Benjamin Lemoine - 2017年9月12日 11:14:47
- jsmack
- 8052 posts
Benjamin Lemoine
Hence the Vertex Split tool.
- uuLLFA
- 90 posts
- dpernuit
- スタッフ
- 553 posts
