I have to merge together multiple pop sim caches together. I didn't make them. They have IDs. However, the IDs overlap because they come from multiple wedge sims. How can I merge multiple point caches together and give them unique IDs?
Thanks.
How to merge point caches together with unique IDs
2520 3 0-
- hibatchi
- 66 posts
- jsmack
- 8085 posts
The easiest way is to add a big number to the id, offset by the wedge index.
This example will work if the caches have less than a million points each, and if there are less than 1000 wedges, otherwise the numbers will become larger than int max.
Another, more sophisticated way is to use a hash function.
Keep in mind the hashes generated are very large numbers, that are non contiguous. They can be used for id matching, or for random number generation without any additional effort. But the numbers are generally too large to convert to float without precision loss. Too convert to a float, either use a random function/vop or use modulus first.
@id = @id + 1000000 * i@wedge;
vector4 vhash = set( @id % 65536, @id / 65536 , i@wedge % 65536, @wedge / 65536 ); @id = random_fhash( vhash );
- hibatchi
- 66 posts
- tamte
- 9053 posts
the safe way is to ensure alternate ids
process each wedge with following code before merging:
where:
numwedges is total number of wedges(merge inputs) you are merging
wedgenum is current wedge(merge input) number (0 based)
that would work no matter how many particles is in each wedge (of course as long as the ids within each wedge are unique to begin with) until you reach int limit
i@id = i@id*numwedges + wedgenum;
where:
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
