Does anyone know what units cloth mass density are in?
The tool tip claims “This is the amount of mass per volume.”
What does this mean?
How do I relate this value to the size of my piece of cloth?
Cloth Mass Density Unit?
5261 8 1- Enivob
- 2631 posts
- symek
- 1390 posts
My guess is that it's density of a matter per unit volume, which is cubic meter in Houdini:
1000cm3 of water weights exactly a ton, because density of water is…, well, 1000kg/m3
In case of cloth:
cloth_weight = area of the polygons * thickness of the cloth * material density.
In case of cloth:
Edited by symek - 2017年10月12日 20:54:58
- Enivob
- 2631 posts
Hmm..I still don't understand what the units are, even if I solve the equation.
Using the equation let's assume I have an area of 1 and a thickness of 1 and I am using the default 1,000 for my Mass Density.
How much does that weigh?
I think I still need to know what is the unit of Mass Density. If it is Kg then my 1x1 grid weight 2,200 pounds. Does that seem right?
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- symek
- 1390 posts
Enivob1000kg == 1m2*1m*1000kg/m3
I think I still need to know what is the unit of Mass Density. If it is Kg then my 1x1 grid weight 2,200 pounds. Does that seem right?Unit of mass density is not kg, but kg per volume, like unit of speed is distance per time interval.
Density unit is mass/volume, so in Houdini it is kg/m3.
Edited by symek - 2017年10月13日 11:06:51
- tamte
- 8839 posts
- Enivob
- 2631 posts
- symek
- 1390 posts
- Enivob
- 2631 posts
So that is 2.2 pounds.
When you write a series of symbols on the screen like 1m2 what does that mean in coding language? Is that one times the variable m to the second power?
I don't understand math symbols but I do understand code.
how do I convert “1m2*0.001m*1000kg/m3 = 1kg” to a function?
Is that right?
float result = 1 * m^2 * cloth_thickness * cloth_density / (m^3);
- BabaJ
- 2129 posts
The series of ‘symbols’ is so that one know what the parts of the equation stand for.
So expressed in code:
float size = 1; // 1m2 or 1x1 float thickness = .001 // .001m float density = 1000 // 1000kg/m3 float result = size * thickness * density; // result represents kg because of the units used in the formula //ie. m2, m and kg/m3
