How to scale linearly with Sop Solver?
   2917   6   1
Hello guys!
I have a math problem, i need scale circles with sop solver, but i need scales linearly, but for each iteraction (frame) scaling acts exponentially.
i tried use some formulation on transform inside sop solver with “log()” but with no sucess…
what i need is circles scaling equidistantly, so i need some trick to scale linearly.
and yes, need reside inside a sop solver.
any ideas?
attached a image showing above the problem, and below (manually made) what i need output…
thanks in advance.
Rod Tebisx | Senior Creature FX TD | London
posted solution on odforce.
vusta
thanks! but for my user case i can't use polyextrude inset, i really need scale linearly the incoming geometry… (a oscillating waveform circle)
Like this?
solver_circle_linear_scale.hip (77.6 KB)
mestela
Like this?
that's practically cheating
mestela
Like this?
exacly!!!
very simple! now understood the node location makes all difference!!
wow. perfect!
thanks man!
with loops fwiw.
CircleLoops.hiplc (75.2 KB)
