delete/dissolve polyline/edge in VEX?
5778 3 0-
- MathieuLeclaire
- 79 posts
- MathieuLeclaire
- 79 posts
I think I understand. It really depends on the context. I have a primitive per polyline so a simple removeprim works in this case. If a primitive has multiple polylines, I need to create new primitives that won't contain the polyline I'm trying to remove.
I'm starting to wrap my head around this. If anyone has suggestions for documentation/tutorials on how to manage geometry in VEX, feel free to share and I'll look into it.
- BabaJ
- 2110 posts
The last argument of removeprim() when set to one removes the points of that primitive.(if no other primitive owns the point/s).
If you set it to zero, the points of that primitive are kept, so in your case you will be able to create a new primitive out of the points of your choosing left afterwards.
Edited by BabaJ - 2018年4月18日 12:22:32
- smoluck
- 20 posts
MathieuLeclaire
did you removed the code you've used ?
i'm searching for that too, but can't find an answer now in your post Mathieu.
