I have an iMac pro at work, the newest one, with a radeon 8 gb.
And I have some delay changing between viewport views, after the change everything works fine but while is changing it kind of freezes for a while.
Anyone else with the same problem on an imac Pro?
Trying to figure out if it is an issue of the hardware (lack of horsepower of the radeon) or an actual bug.
delay changing between viewport views in iMac pro in H17
1683 5 1- nicolashe
- 12 posts
- Midphase
- 833 posts
You're talking about changing between Desktops? I just tested it on my aging 2012 Mac Book Pro which definitely isn't even remotely as fast as your machine and I didn't have any issues. All the Desktop Sets switch within 1 second.
The Viewport views (Perspective, Top, Bottom, etc) also switch really fast, but I suppose it depends on the complexity of your scene.
>>Kays
- nicolashe
- 12 posts
MidphaseNo, I am talking about changing views in the Scene view ( from top to right, etc), and the small delay, 1-2 second, happens even when there is nothing on the scene.
Your 2012 Mac Book Pro may have an nVidia card. I am wondering if it is a limitation in the radeon GPU horsepower.
Anyway I have submitted it as a bug as I think I am ill equipped to do the hardware compatibility test it will require to figure it out. I also have a far more annoying issue with unreliable TAB key to call the TAB menu (also submitted it as a bug).
I am a bit surprised that other people have not experienced this issue, considering that iMac-pros are line products.
- anon_user_37409885
- 4189 posts
- filipw
- 138 posts
Same issue on MBP2017. 1-3 secs of delay switching from perspective, right, front etc. Also middle clicking nodes to get info has become delayed compared to 16.5. Then there are many graphic glitches with input fields … Nothing of this is showstoppers, but still annoying.
In addition, there are a lot that could be made quite a lot nicer like:
- better scaling for retina screens (== all mac screens) (it is very small now, noodles/lines get very thin, text hard to read),
- not letting modal dialogs pullute global window manager
- more support for basic text navigation in editors (cmd+arrow opt+arrow etc, or emacs binding like ctrl-a, ctrl-e)
Should this be reported? Known but not priority?
- malexander
- スタッフ
- 5212 posts
