localisation
   2545   4   0
Is there anything in Houdini to do what Nuke does for localising files? It's a temporary cache to a fast internal disk off a slow network or spindle drive.
Hey fuos,
you could easily create a custom hda that does that for you by pressing a button. using a file cache node…
Cheers
CYTE
Thanks Cyte - really looking for a Nuke-like solution that's elegant, native and robust. My HDA would be neither of those
This is a topic I have been thinking about. I know people would have to deal with this when rendering on the cloud. So I am curious to know what solutions are out there. I am not familiar with how nuke handles this.
For OTLS you can leverage scan paths.. ie get all of the OTLS in your scene and then place a copy of them into something like $HIP/otls
For all other external references you could use variables in paths. $REMOTE_OR_LOCAL_DRIVE/path/to/cache
Then update $REMOTE_OR_LOCAL_DRIVE as needed. You would have to ensure all paths are prefixed with that variable. It would be easy for someone to place a read node and point it to a cache without knowing about that variable.
The trick I am interested in is knowing what external references exist before loading the scene. Which I suppose you could handle by saving a ‘sidecar’ with your houdini scene every time you save, a text file containing all the external references in your scene. This is a little anoying because its another thing to manage and ensure is up to date/
Then on your farm or remote machine before you load houdini:
# check the sidecar
# copy the external files to the remote machine if they are out of date
# update REMOTE_OR_LOCAL_DRIVE to your remote drive root
# load your scene and render
Should work, thoughts?
Would love to know if you got anywhere with this approach? Running into similar issues with otl directories that have lots of files in them.
Thanks,
-Jake
