Problem with nodeless python states
   Views 2993   Replies 10   Subscribers 1
In some situations, nodeless python states lose their ability to generate a mouse click event (hou.uiEventReason.Picked), but other events works as expected. For example, as I noticed, if you use the PolySplit tool or EdgeLoop tool, the subsequent state calls no longer detect mouse clicks.
https://gumroad.com/alexeyvanzhula [gumroad.com]
スタッフ
Can you post your python state code, I'll have a look.
_mab_
Thanks for answer
import hou
class TestTemplate(object):
    def __init__(self, scene_viewer, state_name):
        self.scene_viewer = scene_viewer
        self.state_name = state_name
    def onGenerate(self, kwargs):
        self.scene_viewer.setPromptMessage('Hello World!')
        self._drag_started = False
    def onMouseEvent(self, kwargs):
        event = kwargs["ui_event"]
        reason = event.reason()
        # MOUSE MOVE
        if reason == hou.uiEventReason.Active and self._drag_started:
            print 'mouse drag'
        # MOUSE PRESS
        elif reason == hou.uiEventReason.Start:
            print 'mouse press'
            self._drag_started = True
        # MOUSE CLICK
        elif reason == hou.uiEventReason.Picked:
            print 'click'
        # MOUSE RELEASE
        elif reason == hou.uiEventReason.Changed and self._drag_started:
            print 'mouse release'
template = hou.ViewerStateTemplate('test_state', 'Test State', hou.sopNodeTypeCategory())
template.bindFactory(TestTemplate)
hou.ui.registerViewerState(template)
It is just simple example script. It works well and prints “click” when I invoke mouse click. But it stops generate click events after using EdgeLoop (or PolySplit) SOP state
Edited by Alexey Vanzhula - 2019年2月11日 09:03:28
_mab_
Hi. Is there any news?
スタッフ
Seems to work fine here but I don't know what your setup is and what Houdini version you are using. Could you add a scene with your repro steps please ?
Edited by mabelzile - 2019年2月15日 09:11:59
1. Houdini Linux version: 17.0.491
2. In your image I see mouse press and release events. But click is another event (hou.uiEventReason.Picked), which invokes when mouse quickly released without moving. Can you test my script from Python Source Editor? In my H17 click event occurs and script prints “click”, but only if I don't use polysplit or edgeloop states before.
Thank you!
スタッフ
vux
Thank you!
I get the ‘click’ with my scene as well. Can you try the attached scene ?
test_viewerstate.hip (106.8 KB)
スタッフ
I was able to get the ‘click’ message but after some time, the picked event is no longer generated. I'm not sure it's caused by PolySplit itself, it seems broken even with the python state alone.
Could you file a bug ?
_mab_
PolySplit
Same thing with your file. It is not only PolySplit bug. Something happens with scene viewer. If I start this state in new scene viewer click event starts working until you start using PolySplit state. There are other situations when click event broke scene viewer, but I can't remember when it was
Edited by Alexey Vanzhula - 2019年2月15日 13:04:19
The issue still not fixed in H18
I know this is super late but I ran into the same issue, I fixed it by adding a prev UI Event Reason variable, if it == Start, then it's picked. :p
