Using the rbd material fracture node for the first time.
Transform box and add material fracture node - then click RBD OBJECTS on the shelf.
The resulting fetch transform node in the box1 object has an error “cannot set instance attribute because the dop object geometry does not reference a sop node”. Is this something I should be concerned about? Also on the transform_hres node - I had to add a rest position to get the transforms to work…. I am surprised this had to be added to be honest. Is this the correct workflow?
rbd material fracture and rbd objects shelf tool - error on fetch transforms node
867 0 1- sm909
- 4 posts
