Parameter tab defaults to first Tab
   1191   1   0
When I am grabbing any Controller for the character, the parameters tab I have set up defaults to the first tab. No matter the Tab, it does default to the First Tab. Is there a way to not have the parameters tab default to the first Tab?
Edit: Is there a way to grab the controller and that Tab activates? Instead of manually selecting that tab? In the image, I start out in the L Arm Tab and then I select the LArm IK Trans and the Master Tab activates. Thanks, Glen.
Edited by GlenD - 2019年7月24日 16:49:09
I did notice this only happens when the HDA is locked. When the HDA is unlocked, the selection doesn't switch Tabs in the parameters window.
