render view with logarithmic compression
2572 2 1- jon3de
- 22 posts
I will cross post this topic also here to this forum maybe someone can help me.
https://forums.odforce.net/topic/43598-render-view-with-logarithmic-compression-tone-mapped/?tab=comments#comment-206163 [forums.odforce.net]
I try to find a way to display my renders with a logarithmic compression in the render view. Since mantra has no function to apply a color mapping directly to the image my idea was to do that with a LUT but it seems really hard to find a lut that is creating a “simple” logarithmic compression.
I tried to create a lut myself in cops with soft clip node which gives the desired results but unfortunately I can´t create luts from that vopcop filter. Only from color correction operators.
I would be grateful for some help.
cheers
Jon
cheers
Jon
Edited by jon3de - 2019年11月15日 06:25:07
- jsmack
- 8043 posts
You can't create a lut from vop cop, but you can from a chop. What I've done before is create the lookup using vopchop, and then reference the chop using a lookup cop. Then you can save that as a lut.
You might want to look into the aces profile in the OCIO plugin. That has a built in tone curve.
Edited by jsmack - 2019年11月15日 17:36:41
- jon3de
- 22 posts
hey jsmack,
Thank you very much for your reply. I had a look at the aces profile and installed it. Thats nice!!
The tip with chops is also very intersting. Is it enough to just create a vopchop in chops with the soft clip? Or do I need something else there? Right now it does not really use the copvop in the lookup cop. It gives me just black values.
cheers
Jonathan
cheers
Jonathan
