H18 lopnet scene import cameras
   2386   2   1
I'm testing H18 for the first time and trying to import a camera in lopnet that was created and animated at object level. This camera I'm importing it using a “Scene_import_cameras” node. When rendering using karma it looks pretty blurred (like it has depth of field or something). If I render the same object without the camera it looks correct. My test is on Volumes and instanced spheres to points. If I create the camera inside LOP I don't have the issue. Since H18 is a new world, I wonder if there is a proper way to import a obj camera inside lop or a way to fix the blurred look using scene camera import.
Thank you,
-Al Segura
Set the fstop to 0 on the camera object before importing, or use an edit properties lop to set the fstop to 0 on the camera prim. If you right click the camera in the scene graph, there is an option to add an edit properties node for the selected item.
It works!, Thank you jsmack.
