Alembic Import Performance
   1733   2   1
Hello all,
I'm considering using Houdini 18 for cloth, and probably hair, simulation. But for reasons with which I won't bore anyone, I have to work with subdivided objects exported via Alembic.
When I exported 300 frames, the Alembic file is about 70 gigs. Blender handled it in stride, loading the parts it needed on demand, but Marvelous Designer took about 30 minutes to load the avatar.
Can anyone confirm that Houdini is smart about it, like Blender, and not like MD?
Thank you,
Donald
スタッフ
Houdini lazily loads Alembic data. It should only load data as needed from the Alembic archive. If you only look at a single frame of the data, it will not pull in the other 299 frames.
derrick
That's what I needed to know. Thank you.
