Bend SOP issue...
   1946   6   0
Hi;
In “Bend” SOP, I would like to use a group name to bend some part of my geometry, but it doesn't show my group name, in the select group tab!
Is this a bug?
Thanks.
Masoud Saadatmand (MSDVFX)
if it's not in drop-down menu then probably it's a bug
What version you using? I'm using 318 and don't have that issue.
Also, did you try entering the name of the group manually?
I can't remember which nodes but with H18 I've had situations where the group name wasn't available in the drop down menu, but if I entered the name manually it still worked fine.
The group list may not be populated if the group node hasn't cooked, such as when loading a scene in manual cook mode.
BabaJ
I use 18.0.287
I enterd name manualy, but it doesn't work.
スタッフ
This bug was fixed in Houdini 18.0.307.
Thank you “Derrick”.
