18.0.352 Linux
I'm noticing that it's hard or impossible to resize Houdini windows. Optype Properties, floating Textport/Python, the file browser or any other window.
Feels like a Qt thing but I can't be sure. I grab the edge and drag and after a few pixels my mouse “detaches” from the window, and stops resizing.
Other apps on my machine have no issues resizing.
Anyone else facing this?
Peter B
Linux: resizing Houdini window(s) hard/impossible
8041 29 5- pbowmar
- 7046 posts
- protozoan
- 1719 posts
- pbowmar
- 7046 posts
- pbowmar
- 7046 posts
- protozoan
- 1719 posts
Hm, tested it explicitly with stage context again, but to no avail, it works.
(Testing against nvidia 440.44, Openbox, picom compositor on and off both work)
Admittedly, during the beta and RC phase, stage was kind of glitchy for me, but that has improved since.
Martin Winkler
money man at Alarmstart Germany
- anon_user_37409885
- 4189 posts
- pbowmar
- 7046 posts
- rvinluan
- スタッフ
- 1283 posts
Yeah. I'm looking into this problem. I can reproduce the problem with Kubuntu 18.04 LTS but not GNOME Ubuntu 18.04 LTS. It's definitely KDE related.
One thing I notice is that if I try to resize the window enough times then all of a sudden the issues disappear and resizing goes back to normal.
I suspect that KDE desktop effects or some other windowing setting is not playing nice with Qt 5.12. I'll post here when I have more info.
Rob
Rob
- rvinluan
- スタッフ
- 1283 posts
- 4189 posts
- pbowmar
- 7046 posts
- danyargici
- 19 posts
- graham
- 1922 posts
- danyargici
- 19 posts
It's really frustrating. Seems to be a regression that happens with each major release since H18.
https://www.sidefx.com/changelog/?journal=18.5&categories=&body=kde&version=&build_0=&build_1=&show_versions=on&show_compatibility=on&items_per_page= [www.sidefx.com]
https://www.sidefx.com/changelog/?journal=18.0&categories=&body=kde&version=&build_0=&build_1=&show_versions=on&show_compatibility=on&items_per_page= [www.sidefx.com]
- danyargici
- 19 posts
19.5 is out and this issue remains to be a huge pain for our studio.
I submitted a bug report shortly after my first post and was told there was an existing ticket (#118701).
It's very disappointing to see this issue persist, especially when it appears to be a regression that has been addressed at least twice in the past!
- rvinluan
- スタッフ
- 1283 posts
danyargici
We have been investigating the latest window resize issue for many weeks now and the good news is that we've identified the cause. Without going into too much detail, the issue is caused by a behavior change in Qt for a widget property that Houdini relies on. The behavior change happened when we upgraded Houdini 19 to Qt 5.15. This was similar to a behavior change in H18.0/18.5, when Houdini was upgraded to Qt 5.12 at the time, that caused the window resize issue in those versions.
Unfortunately, the behavior change in Qt 5.15 is not something we can completely fix or avoid like we did in the past. We are currently looking into potential workarounds, ones that will avoid the window resize issue but may have tradeoffs. Such workarounds will be optional. The user will have to opt into the workaround via an environment variable. We are aiming to have a workaround in place shortly.
In the long run, we are also looking at some internal re-architecting for future Houdini releases so that Houdini no longer relies on the Qt widget property related to the window resize issue.
Rob
- rvinluan
- スタッフ
- 1283 posts
For what it's worth, here's a KDE bug report on the window resize issue triggered by the same Qt widget property that Houdini relies on:
https://bugs.kde.org/show_bug.cgi?id=435717 [bugs.kde.org]
Rob
Rob
Edited by rvinluan - 2022年8月17日 08:53:23
- rvinluan
- スタッフ
- 1283 posts
Hi All,
Heads up that tomorrow's 19.0.720 build will have a workaround in place for the window resizing issues on KDE. The workaround is disabled by default. To enabled the workaround, set
The workaround does have one caveat -- the UI will not auto-redraw when dragging another window over it. To force the UI to redraw after dragging a window, you need to click on the UI.
I wish we could have put in a fix without any caveats but unfortunately this is the best we could do without any major re-architecting. We have planned changes in the next Houdini release to avoid the Qt::WA_PaintOnScreen attribute and put it in a proper fix.
Rob
HOUDINI_KDE_RESIZE_FIX=1
in the environment before launching Houdini.The workaround does have one caveat -- the UI will not auto-redraw when dragging another window over it. To force the UI to redraw after dragging a window, you need to click on the UI.
Rob
- jason_iversen
- 12672 posts
Hi Rob!
It this available for 19.0? I can't get the Changelog to list older platform entries anymore, e.g. specifying 19.0 in the Version form field -- is it broken?
- rvinluan
- スタッフ
- 1283 posts
jason_iversen
Hi Rob!
Hi Jason,
Yup. The change is available as of build 19.0.720.
Here's the changelog:
https://www.sidefx.com/changelog/?journal=19.0&categories=&body=&version=&build_0=&build_1=&show_versions=on&show_compatibility=on&items_per_page= [www.sidefx.com]
You might be right about the Version field being broken. I'll check.
Rob
