Hi, I'm learning how to use Houdini and following some tutorials from Applied Houdini, speaking of following the tutorial, I'm fine and learning a lot. Still, I come across a small issue and can't find the solution. I'm using Houdini 17.5, I'm applying the Voronoi and visualising the different pieces, but after packing the geo with the Assemble node, I can't see those visualisations, I thought was something correlated with the Cd attribute but I can't get it back, I followed that video so many times. I'm doing it the same, although he uses v16. Any workaround?
Kind regards,
Giovanni.
Color visualisation disappears
2379 2 1- farigiovanni
- 4 posts
- jsmack
- 8041 posts
- farigiovanni
- 4 posts
