We are trying to set the Static Mesh Method to UHoudiniStaticMesh in Houdini instead of Unreal. Also Disable the Affect Distance Field Lighting. This helps with the asset not Generating Mesh Distance Fields every time we move a point on the curve.
We have tried using an Attribute Wrangle set to Detail with @unreal_property_StaticMeshMethod = 2; This did not work for us.
Is there a way to change this property inside of Houdini and not Unreal?
Edit - Added new image
[Solved] Set Static Mesh Method attribute in Houdini
4427 3 1- GlenD
- 118 posts
- dpernuit
- スタッフ
- 553 posts
StaticMeshMethod is a development only property. that's mainly used to test/debug mesh creation issues with v2 while it's in Alpha.
It will likely disappear once the v2 plugin is properly released.
If you want the plugin to generate proxy meshes (HoudiniStaticMesh) by default, you can change that in the plugin settings:
Under Static Mesh, “Enable Proxy Mesh”.
Further options are available to control how/when proxy meshes are refined to Static Meshes.
You also have per HDA overrides accessibles via the details panel.
As for the distance field property, we don't apply the uproperties on the HoudiniAssetActor, but only on the output generated by the HDA. That property should stay disabled upon recook/rebuild though, but currently, you'll have to set it manually.
- GlenD
- 118 posts
- Len
- 133 posts
