textures lost after unpack
   1151   0   0
i´ve got quite a simple setup. i have a moving figure and i apply a pointdeform to a piece of junk, that should move the same way.
The piece of junk is a redshift proxy object, it renders fine, but i need to unpack it in order to make it move correctly.
Sadly i lose the texture in the process. I tried to promote to primitive attributes and point attributes with a * flag.
But then redshift crashes and houdini becomes unresponsive.
I also tried an attribute transfer, same problem, i also tried to cache thinks out, also the same.
In order to get the texture, which attributed do i need, to restore the texture (uv and Cd? primitive or point attribute) and which would be the best way to do it?
thank you
Edited by hochenauer - 2021年5月20日 08:45:34
