HDA Very Slow with Mesh Distance Fields in UE4
2334 2 0- Sorai
- 5 posts
- gt3d2019
- 40 posts
- Sorai
- 5 posts
gt3d2019
I havent had need to use it yet, but under mesh generation hda details the default is set to generate raw mesh which goes through all the unreal import options, you could try switching it to Houdini mesh,which in theory gives you a more simple mesh, then revert when yer settings are what you want
Thank you! This seems to have worked.
