Hi all,
I've done a short animation using Apprentice 8.2.13, and tried to render it by creating an IFD file and then sending it to mantra. The problem is than I cannot check the “Generate Script File” button, as it remains grayed out.
I there any special sequence of options I should use to make it work?
TIA,
Doron
"Generate Script File" is grayed out
2894 2 1- doronko4
- 5 posts
- jason_iversen
- 12670 posts
The reason for it being grayed out is because it's limit set up for Apprentice only. For paid licenses this is enabled, of course.
Hope this helps,
Jason
Hope this helps,
Jason
- doronko4
- 5 posts
