Now when we're in the age of working remotely I have tested parsec and It's pretty good. I can even animate and get decent playback.
The problem came when I tried the virtual displays setting. When I turn it on Houdini crashes on startup. All other apps I have tried seem to work.
Parsec and virtual displays
5745 7 2-
- haymaker
- 7 posts
- made-by-geoff
- 84 posts
- haymaker
- 7 posts
- Drewzee
- 17 posts
- urdro
- 2 posts
Drewzee
I get this same problem every time using virtual display driver.
Try adding this to ENV file in your documents folder under Houdini , it worked for me.
HOUDINI_USE_HFS_OCL = 0
You have perfectly solved my problem. Thank you very much.
I used Parsec Virtual Display. When I remotely controled Houdini, the program crashed.
But after I added this line of code to the .env file, Houdini can now open normally.
- gottesgerl
- 3 posts
- Marco Fontan
- 9 posts
- TechC14
- 1 posts
