When I'm using the environment light with hdri images, it doesn't work.
Please help.!
mantra: Unable to load texture. I cannot use the hdri images
1328 1 1- expertyuuu
- 3 posts
- David Krepelka
- 15 posts
The green background is a geometry you made, right? I would say something from the envlight is working, because you have smooth shadows and only a distantlight would always create hard shadow edges. When you hide the green background and press "Render Light Geometry", is the HDRI texture showing up?
You can also try it in a fresh and clean Houdini file with only a grid, a box and the envlight with the HDRI. Is it working there?
