Multiple FBX and bgeo Output
   1869   2   1
I currently have a test scene exporting basic shapes in groups. In the TOPS network I use an importgeometry node to index each group. This works fine when I output the geometry using a ROP Geometry Output node. Each group is output as a separate file. The second setup is a ROP Fetch node. Same parameters as the ROP Geometry Output. The ROP Fetch does not recognize the groups and only outputs all the geometry. Has anyone encountered this issue before?
I have included a sample file of the issue. The geometry needs to be processed again to appear. Thanks.
Houdini Version: 19.0.455
Glen
Edited by GlenD - 2022年3月27日 06:01:18
A_Test_TOPS.hip (279.3 KB)
Because the pdg_index specified in the path will not select the geometry by group in any way. You need before saving to ROP
FBX Output remove geometry by `@groupname` for this to work in ROP Fetch.
alexwheezy
Thanks alexwheezy,
Such a simple fix, thanks!
Glen
Updated File included.
A_Test_TOPS.hip (280.4 KB)
