force render proxy purpose geo
2518 6 0- leoYfver
- 31 posts
Im trying to figure out if its possible to switch a component to force render the proxy purpose instead of render while rendering with karma.
The goal is to be able to switch parts of the environment for example to render as purpose proxy when they are in phantom. Escpecially when they are reference instance as in the example below.
Does somebody now if this is possible, or would solve it in another way with creating variants from the proxy puropse or inherits perhaps?
cg supervisor @goodbyekansas
- antc
- 325 posts
- leoYfver
- 31 posts
Yes sound like probably the way to go. I wonder if its possible with the component builder to make a variant out of the purposes. The problem now is that we need to do both. One variant setup with the *component geometry variants* node and iniside as purpose. Would be cool if we can get a proxy variant out of the purpose output. Cant really wrap my head how to do that though
- antc
- 325 posts
There's a handy node called "component geometry variants" that works in conjunction with the component builder that allows you to plug in multiple component geometries as input and it creates variants automatically. So a second component geometry that just grabs the proxy geo from the first and plugs it into the render geo seems to work ok.
Edited by antc - 2022年4月5日 11:55:52
- tamte
- 8730 posts
- leoYfver
- 31 posts
- Illogic
- 3 posts
Hello !
Bumping this post because I'm looking to do the same.
I have a setup working with two configure node.
The first configure node edit the proxy primitive to change it's purpose to render.
The seconde configure node edit the original render primitive to change Activation to off.
Is it ok to do that, or is there a better way ?
Thanks !
Thanks !
