How to automatically partially change an expression link
   1139   1   0
Hello. I have a question, maybe you can help me. I have a link to a parameter in Houdini - chs("../../param_2/Shot_021") and I need to change the penultimate two digits "02" with the slider, just copying a new link here does not work. Maybe you know a way?
test.hip (179.6 KB)
I attached a file with a few ways of doing it, easiest is probably to just write this as an expression for your parameters:
chs("../../param_2/Shot_"+padzero(2, ftoa(ch("select_shot")))+"1")
I hope that helps.
test_test_123.hipnc (210.3 KB)
