Textport - renaming multiple paths
   878   1   0
Hello
I'm just trying to automatically rename multiple paths for a number of embedded files in an HDA using the textport.
The original paths are:
$HIP/FINAL_FBX/xxx.fbx
So using this:
opchange \$HIP/FINAL_FBX/ opdef:../..?
However the forward slash after the FINAL_FBX is causing a problem and it wont run.
If i use without the '/' it works fine, but then I still have the / in the new path so its not correct
opchange \$HIP/FINAL_FBX opdef:../..?
Must be somthing to do with the last / but i can figure it out?
Love Houdini
Figured it out i needed the -i option and to do it as a string:
opchange -i '$HIP/FINAL_FBX/' 'opdef:../..?'
Love Houdini
