I'm trying to model a house and I used polyExtrude to make the walls. Now I want to selected the extrudedSide group which are facing inside to the home, excluding the outside ones. I thought that I can use something like select by angle feature but I couldn't find anything like this. How do you handle this situation, how would you select these primitives? I attached a screenshot which you can understand what I mean for.
How to select extrudedSide by excluding the out faces
1367 3 0- Hazart
- 8 posts
- robsdesign
- 236 posts
Hi, I've attached a hip file showing two methods, I expect there are others.
The first method will only work with that particular shape as it uses a bounding box group. The second method relies on doing the extrude after you have the group (so you can use extrude's front/back grouping to intersect with the previous extrudeside).
Rob
Rob
- Hazart
- 8 posts
- robsdesign
- 236 posts
Hi Hazar,
Houdini does have grouping by angle. It's on the group sop under Include By Edges where you can set min/max angle. The problem is it won't help with this particular grouping.
This is all assuming you need procedural grouping. If you don't and nothing changes upstream, probably quicker/easier to just select the group manually. (to select loops: left-click poly, hold shift+a, middle-click next poly)
Rob
Rob
