Error in ROP Geometry Output Node
   1482   0   0
Segment Fault occurs while cooking an external SOP with ROP Geometory Output.
It may or may not occur, but I am not sure of the conditions to reproduce it.
I have attached the node we are using as HDA and would appreciate it if you could check it.
Houdini Environment is as follows
Houdini 19.0.657(steam)
Processor AMD Ryzen 9 5950X 16-Core Processor 3.40 GHz
128 GB of RAM installed
windows 11
error & stack trace
Running Houdini 19.0.657 with PID 33972
HFS = 'C:/PROGRA~2/Steam/STEAMA~1/common/HOUDIN~1'
HOUDINI_TEMP_DIR = 'C:/Users/trsni/AppData/Local/Temp/houdini_temp'
HOUDINI_PATH = 'C:/Users/trsni/AppData/Local/Temp/houdini_temp/apartment/pdgtemp/10928;C:/PROGRA~2/Steam/STEAMA~1/common/HOUDIN~1/packages/kinefx;C:/Users/trsni/Documents/houdini19.0/SideFXLabs/19.0.563/SideFXLabs19.0;B:/Public/Bridge/support/plugins/houdini/4.5/MSLiveLink;&'
Loading .hip file C:/Users/trsni/Documents/GitHub/hip/apartment.hiplc.
ROP node path '/obj/geo1/trsni_UVMappingScheduler5/process_scheduler/ropgeometry2/ropnet1/geometry1'
ROP type name: 'geometry'
ROP source path: 'Internal'
Checking for custom output parms '' on node '/obj/geo1/trsni_UVMappingScheduler5/process_scheduler/ropgeometry2/ropnet1/geometry1'
Cooking node using 'hou.Rop.render'
33972: Fatal error: Segmentation fault
-- TRACEBACK BEGIN --
Traceback from hython 19.0.657 (Compiled on windows-x86_64-cl19.29):
CURRENT THREAD 12436
+0x2376dfd4 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libGU.dll
+0x237a2de5 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libGU.dll
+0x2379876d C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libGU.dll
+0x23794c75 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libGU.dll
+0x237918c4 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libGU.dll
+0x2378d303 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libGU.dll
+0x2378d47a C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libGU.dll
+0x1b50d0cc C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x1b50a2b5 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x1b51227c C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x1b501717 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x1af55e28 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x1af546ba C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x110e01db C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libOP.dll
+0x110ee06c C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libOP.dll
+0x1af4b50c C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x1a888954 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x1110ba4e C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libOP.dll
+0x111109ca C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libOP.dll
+0x1af5d6a6 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x1b3e58c6 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x10fcc171 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libOP.dll
+0x1af526d2 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x1a718b7e C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x1af54a21 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x1af974b0 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
+0x1b242163 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libSOP.dll
OTHER THREAD 17388
+0x7ff936f24034 C:\WINDOWS\SYSTEM32\ntdll.dll
+0x7ff9339810ab C:\WINDOWS\SYSTEM32\MSWSOCK.dll
+0x7ff9368454e0 C:\WINDOWS\System32\KERNEL32.DLL
+0x7ff936e8485b C:\WINDOWS\SYSTEM32\ntdll.dll
OTHER THREAD 24104
+0x7ff936f24594 C:\WINDOWS\SYSTEM32\ntdll.dll
+0x7ff936edbb23 C:\WINDOWS\SYSTEM32\ntdll.dll
+0x7ff9348bb361 C:\WINDOWS\System32\KERNELBASE.dll
+0x12953678 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libUT.dll
+0x12953573 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libUT.dll
+0x7ff934746c0c C:\WINDOWS\System32\ucrtbase.dll
OTHER THREAD 17380
+0x7ff936f23f94 C:\WINDOWS\SYSTEM32\ntdll.dll
+0x7ff9348b2a0e C:\WINDOWS\System32\KERNELBASE.dll
+0x2a28f572 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\tbb.dll
+0x2a28f45b C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\tbb.dll
OTHER THREAD 13412
OTHER THREAD 17056
OTHER THREAD 8012
OTHER THREAD 17372
OTHER THREAD 24172
OTHER THREAD 18848
OTHER THREAD 18676
OTHER THREAD 8676
OTHER THREAD 8684
OTHER THREAD 8008
OTHER THREAD 23980
OTHER THREAD 18436
OTHER THREAD 18412
OTHER THREAD 24156
OTHER THREAD 24476
OTHER THREAD 31092
OTHER THREAD 6820
OTHER THREAD 24128
OTHER THREAD 20512
OTHER THREAD 6132
OTHER THREAD 21316
OTHER THREAD 7560
OTHER THREAD 29284
OTHER THREAD 14600
OTHER THREAD 33528
OTHER THREAD 34368
OTHER THREAD 7036
OTHER THREAD 23600
OTHER THREAD 22172
OTHER THREAD 7580
OTHER THREAD 23824
+0x2b7c9ad8 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libPDGD.dll
+0x1294d9a4 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libUT.dll
+0x1294dda9 C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libUT.dll
OTHER THREAD 2976
+0x7ff936f24a64 C:\WINDOWS\SYSTEM32\ntdll.dll
+0x7ff9348bfb60 C:\WINDOWS\System32\KERNELBASE.dll
+0x7ff9348bfa5e C:\WINDOWS\System32\KERNELBASE.dll
+0x7ff85c81aaa4 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_b7184c0e1c94c102\nvopencl64.dll
+0x7ff85c8c231d C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_b7184c0e1c94c102\nvopencl64.dll
+0x7ff85c81a473 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_b7184c0e1c94c102\nvopencl64.dll
+0x7ff85cb49b94 C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_b7184c0e1c94c102\nvopencl64.dll
OTHER THREAD 27768
+0x7ff85c641bfd C:\WINDOWS\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_b7184c0e1c94c102\nvopencl64.dll
OTHER THREAD 9868
OTHER THREAD 2532
OTHER THREAD 2544
OTHER THREAD 6992
OTHER THREAD 30480
+0x29e57f3d C:\PROGRA~2\Steam\STEAMA~1\common\HOUDIN~1\bin\libPDG.dll
OTHER THREAD 1972
OTHER THREAD 11288
+0x7ff936f27ac4 C:\WINDOWS\SYSTEM32\ntdll.dll
+0x7ff936e96fdf C:\WINDOWS\SYSTEM32\ntdll.dll
OTHER THREAD 11412
OTHER THREAD 32524
OTHER THREAD 34576
OTHER THREAD 15108
OTHER THREAD 32652
OTHER THREAD 21696
OTHER THREAD 27392
-- TRACEBACK END --
trsni_UVMappingScheduler.hdalc (101.1 KB)
