GlueAdjacent not in my rigid shelf tools
4181 8 2- dansperfect
- 3 posts
- chrism
- スタッフ
- 2551 posts
If you search for Glue Adjacent in the changelog/journal you'll find it:
19.5.79
Removed the Glue Adjacent shelf tool. Tools such as RBD Glued Objects should be used instead to create constraints ahead of time in SOPs, rather than creating a DOP -> SOP -> DOP cycle.
Wed. November 24, 2021
19.5.79
Edited by chrism - 2022年8月26日 15:09:36
Chris McSpurren
- ctedin
- 69 posts
- cwhite
- スタッフ
- 750 posts
- tamte
- 8833 posts
cwhite
If you have the static object's geometry in SOPs, with a name attribute assigned, then tools like RBD Constraints from Rules, or even just Connect Adjacent Pieces, can be used to create constraints between your fractured object and the static object
but if you need to bring them to SOPs in the first place isn't that what the tool was doing?
I agree that its not ideal, especially since it was creating the SOPnet outside of the DOPnet
I'm mostly talking about RBD solver, since for Bullet all prep happens in SOPs to begin with so this tool would not be necessary
but I assume for people that have to fall back to RBD solver (if they want mutulal FLIP interaction or something) it may still be useful
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- cwhite
- スタッフ
- 750 posts
- tamte
- 8833 posts
cwhiteAh, ok, yeah, it's slowly coming back, haha, then it's probably better removed
The Glue Adjacent tool wouldn't have worked with the RBD solver since it creates constraint networks For the RBD solver I think you'd have to use the Glue to Object parameter on the RBD Object DOP to set up the old-style glue
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- ctedin
- 69 posts
- anatolij.zykov
- 1 posts
