Hey, my redshift isn't showing in my houdini.
This is windows 10 pro. first time installing them. I tried added the following line to houdini.env
HOUDINI_DSO_ERROR = 2
PATH = "C:/ProgramData/Redshift/bin;$PATH"
HOUDINI_PATH = "C:/ProgramData/Redshift/Plugins/Houdini/${HOUDINI_VERSION};&"
which doesn't help, and also tried follow tutorial adding redshift.json to the package folder, still not helping...
https://www.youtube.com/watch?v=u787XP5Gbes [www.youtube.com]
Please help :< is my redshift problem or..
newest Houdini 19.5.368 install Redshift 3.5.8
13506 4 2- anannie1015
- 1 posts
- CYTE
- 709 posts
- CYTE
- 709 posts
- iakkm
- 2 posts
- cdordelly
- 162 posts
iakkm
HI, does Houdini 19.5.493 supports all Redshift versions upon 3.5.12 or it just works with the 3.5.12, installing the plugin from the link that @CYTE attached (?)
Hi! In theory Houdini 19.5.493 supports from Redshift 3.5.13 to Redshift 3.5.14
You can check the supported versions of each build here:
https://help.maxon.net/r3d/houdini/en-us/index.html#html/Houdini+Plugin+Configuration.html#Plugin [help.maxon.net]
There is indeed a RS 3.5.12 custom build on the RS Houdini Custom Builds thread, so in theory that one should work for H19.5.493 too.
