Houdini 19.5 | Epic Speed Modeling | Kitchen
   3352   8   2
In this video, I am doing something that usually you don't think about when you mention Houdini, but here we are.
https://www.youtube.com/watch?v=pjUmOwIYzuQ [www.youtube.com]
QA Specialist at Greyscalegorilla |PolyMarvels YT: https://www.youtube.com/channel/UCqXuTLiaL-jqvn3LK1XlwHg [www.youtube.com] | Instagram: https://www.instagram.com/polymarvels/?hl=en [www.instagram.com]
Hello @SIgor420, thank you to show this.
It's happy to this in the light because yes we can use houdini for any kind of modeling stuff and also for "architectural" work.
I personally use it for this without need of any sort of "modeler" plugin (as well it can be) to achieve lot of stuff with te benefit of the proceduralism way on the fly when needed.
Here is a quick update and WIP. I plan to make a tutorial on how to apply materials in an easy way etc. This one should be fun!
julca
I personally use it for this without need of any sort of "modeler" plugin (as well it can be) to achieve lot of stuff with the benefit of the proceduralism way on the fly when needed.
Glad to hear I am not the only one. For these kind of things Houdini is really great. Its not without flaws, but it definitely comes with some benefits too, so in the end its a trade of.
Final update for the night...
couple of points:
This is not speed modeling, it is a sped-up video of modeling. Not the same.
On the front page it is under "Masterclass" section. A non-narrated video that is x10 of original speed has nothing to do with "Masterclass" tag (can't edit my comment there, so clarifying here).
Edited by osong - 2022年10月8日 05:53:26
https://twitter.com/oossoonngg [twitter.com]
osong
Also, on the front page it is under "Masterclass" section. A non-narrated video that is x10 of original speed has nothing to do with masterclass (can't edit my comment there, so clarifying here).
I am not sure whats the point of your comment but let me clarify as it seems that you are jumping to conclusions far to easy.
So, first things first its called speedmodeling cuz everyone calls sped-up video speedmodeling, so I did it too. Second thing, uploading a videos doesn't give much flexibility when comes to choosing beginner, intermediate or masterclass, so I was like, ok this is definetly not beginer stuff, not even intermediate so I chose Masterclass because I had to choose one. Also, I was aware that this is not tutorial as you said, so BEFORE I uploaded that video, I asked SideFX is that ok or not, and they said its ok, so I shared the video for two reasons here. 1st to make people aware about my channel and to ake people aware what you can do in Houdini even though many says its no for that, so hopefully this clears a bit things for you. On the other hand, I do have plans to make new modeling tutorials as I came up with a lot of new things and workflows in past 6 month while not recording. Hopefully that helps clear few things for you.
And you as a content creator, I would expect more respectful comments then just 'lmao', at least proper feedback or constructive criticim. It makes me a bit sad as I pretty much watched all your videos and respect what you do. Fro all people you should know making tutorials is not easy, especially when you have full time job.
Edited by PolyMarvels - 2022年10月8日 06:06:14
like i said, i couldn't edit my initial comment, and i did immediately regret writing the "lmao" part, alas i can't undo it apparently, so i took it here to explain myself better
still, this is definitely not a masterclass
osong
Ok, Ill ask SideFX to change it, not a problem.
Aaaaand to continue in positive note, here is a little update...
