Extracting only rows of edges from a mesh
   2359   2   0
Hi everyone!
I am trying to extract all "long" lines from this alembic mesh
My first assumption was to somehow use the fact that they go along the U coordinate.
I used a simple expression to store the original position and convert this mesh to a "UV grid"
v@PStore = @P;
@P = @uv;
This made things look easier but I still couldn't figure out how to keep only the horizontal lines.
So I wrote a script that would delete the vertical ones based on their length since I was lucky that all of them had a larger @restlength.
In the end after restoring the @P to the one I stored earlier I achieved the result but I am sure that there is a more elegant way to select only the "U" prims.
I would appreciate any pointers on a more logical way to achieve that result.
Thank you
Edited by Robot_and_Robot - 2022年12月6日 06:44:20
スタッフ
Take a look at the Group Find Path SOP. It can likely simplify this task. Attached is an example of a mode that may be helpful for this task.
groupfindpath-example.hip (107.9 KB)
derrick
Great! Thank you so much!
