Labs flipbook render spitting out an error on every pass
   1135   1   1
hi there!
I keep getting a console error when generating the passes for FlipBook renders. It's the same error for every pass. It seems to be correctly generating the textures though. Anyone else getting this?
thank you!
  File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.493/houdini/python3.9libs\houpythonportion\qt\ViewerOverlay.py", line 57, in closeEvent
    self._scene_viewer.removeEventCallback(self._onViewportEvent)
  File "C:\PROGRA~1/SIDEEF~1/HOUDIN~1.493/houdini/python3.9libs\hou.py", line 77356, in removeEventCallback
    return _hou.SceneViewer_removeEventCallback(self, callback)
hou.ObjectWasDeleted: Attempt to access an object that no longer exists in Houdini.
Hello!
I can imagine you solved this in the ~year since you posted the message. However, for the benefit of any others that may come across this, I was facing a near identical error in Houdini 20. To resolve this I upgraded SideFXLabs to version 20.0.687 and was then able to render out the textures.
Hope that helps
