Hey
Actually, I try to load HDA from Houdini Engine for Maya and I got this error I don't know why this happened.
// Error: Could not load OTL file: D:/HIP/HDA/Forcy__forcy_barrel.otl
I try to make a custom HDA and I got the same error, so I try to use one from the free HDA I got the same
Error , need some helps
1395 1 0- bondok
- 1 posts
- johnmather
- スタッフ
- 514 posts
I just tested with the same asset and it loaded properly. Could you please do the following:
In Maya, load the asset.
In the menu bar, go to Houdini Engine>Debugging>View Assets in Houdini
This will open Houdini and show you how Houdini is interpreting the Maya scene. Are there any errors that you can see there?
