Hello
I have a very simplified sim to show you what my problem is.
two simple flip volume sources, I want one of them to ignore the collision plane.
I couldn't do it in flip sop as well, yeah more good news.
I really appreciate any help you can provide.
flip collision exclusion
1218 3 1- MirHadi
- 147 posts
- MirHadi
- 147 posts
- tamte
- 8730 posts
popcollision ignore will just ignore particle collisions, which in flip are just secondary to volume collisions and purely optional, they don't contribute to fluid motion, just help to keep advected particles not pass through colliders
pressure projection needs proper volume collisions
if you want to make some region of volume collisions "transparent" (the transparency option in Collision tab) you can zero out "collisionweights" field around particles you don't want to collide
keep in mind that volume vel field is solved for the whole sim and all particles will use it so there is no specific way to separate that some particles will properly collide with volume colliders ehile other will pass through in the same region
since all particles are advected by the same field
if however you do tweak "collisionweights" make sure that you either keep your particle collision ignore settings to reflect the same behavior or set particle collisions to None
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- MirHadi
- 147 posts
