PDG and import usdfiles from a clip file
   1200   1   0
I try to gather all files needed for a usd layer in tops with usd_import_files.
It worked so far for most cases, but I had to switch to stitched clips and now it does not get all files needed. it stops at clip, manifest and topology.
The actual usdc files that are in the clip do not show up as items in the graph.
Unless I display the clip file in a Solaris view, then pdg is able the get all the files down to the lowest level. When I scrub the time line even the complete range is collected
I prepared a little demo setup to show the behavior
It would be best if the usd_import_files now would be able to collect all files that are needed for this layer
if anybody has a idea how to solve his without displaying the clip usda in a viewer, it would be super helpful
thanks for You time
Martin
Edited by sanostol - 2023年6月19日 14:40:29
stitching.hip (142.5 KB)
In another attempt I tried to do it with python by querying the scene graph but it behaves quite similar
