RBD Convex Proxy with multiples of the same object
   594   0   0
I have a problem with trying to have multiples of the same object in an RBD Convex Proxy setup.
I know RBD is really looking for the same name and then uses transform pieces with the same name to transform highres geo to the low res proxies.
What I need is to spawn loads of the same low res objects onto points (so they have the same name but just one highres parent geo) and then I need to essentially copy to points the high res geo onto the low res instances. However that doesnt seem to work. Copy to points just takes the highres geo from world origin and transforms it according to how the low res geo is moving which is not at world origin. So the problem ends up with the high res geo essentially being offset and animating with all those offsets.
How do I solve this offset issue? I have included an example file.
Copy_to_Points_Problem_01.hiplc (497.6 KB)
